Search for tools and product advice,
Discuss Touch dimmer switch in the UK Electrical Forum area at ElectriciansForums.net
leep82
Not fitted any before and was just after some advice. Been asked if i can fit one for a customer having a rewire done. In there living room they currently have a four gang switch, four wall lights switched in pairs and two centre lights switched seperately. They want to keep this arrangement but would like to have touch dimmer switches rather than a rocker switch. I initially misunderstood the client when she was telling me what it was she wanted and just assumed it was a normal dimmer switch she was referring to so said it shouldnt be a problem if i changed the 25mm back box for a 35mm. Having spoken to her since and now knowing this isnt the sort of dimmer she requires but actually the type referred to in the thread title, i was just wondering theres anything different/special about them. Is a 35mm back box deep enough? Would i need a neutral at the switch? Any help/advice greatly appreciated
I have fitted a single at my dads house. It needed a 35mm box but did not require a neutral. Also can be programmed to any remote control spare button without buying the fancy remote they suggest
They come pre programmed to work with buttons 1 & 8 on the remote, and they're pretty easy to programme to spare buttons on other remotes
Reply to Touch dimmer switch in the UK Electrical Forum area at ElectriciansForums.net
Novice here wondering what I might be missing. Thanks for any help. I am swapping out an old switch in the bathroom to a dimmer switch. When I...
This is confusing, I've ordered a few bits of this stuff, some switch modules and front plates and in the bumf on the website it says:- Click...
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
My daughter is asking me if it’s possible to change her double light switch outside her bathroom to a dimmer. It’s a 2 gang switch that turns on...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
