Discuss Tricky (to me at least) 4-way switch problem in the UK Electrical Forum area at ElectriciansForums.net
easiebold
I've inherited a home with wiring in place but not all connected. I can't locate the original electrician who did the work about 2+ years ago.
I have four switches. Line power goes into switch 1 (a 3-way switch) then over via 3-wire cable to switch 2 which has a feed to 4 can lights (install a 4 way switch?), then a 3-wire cable over to switch 3 (another 4-way switch?) which has another feed to another 4 can lights and yet another 3-wire cable to switch 4. At switch 4 I have two wires back to switch 3. At switch 4 I also have two wires which need constant (UNswitched) power for a stove hood vent feed and an outdoor fixture.
I've drawn several possible wiring diagrams, attached wires in several configurations, and generally spit into the wind for about two weeks.
The only line power I can determine is at switch 1.
After watching many, many UTube videos I found this forum.
Can anyone come up with a workable schematic I can use?
Thank you in advance!!
Allen
How about using a wireless switch, like a Quinetic Wireless Switch? Then you can have your four switches controlling the light, without having to sort out the wiring of the switches.
I think professional electricians can pinpoint and fix electrical issues, saving you significant time. They use their expertise to resolve the situation quickly.
bostonelectricma: I tend to agree. Two days after my original post I did finally locate the originating electrician. Then I saw him when he made a purchase at the big orange box store I work at. He told me to call him. I called him three times and left messages with my name, address and phone number, asking for an cost estimate for finishing the project. I have a photo now of his truck with name and phone number so I know I called the correct number. When he finally returned my call (a week ago), he told me that he was 'no longer interested' in the project (I guess at any cost). Previous to finding him I had contacted two other electricians who performed other work at the house--'not interested' in finishing someone else's work.
So I did what I should have done at the beginning-- I added an additional feed and changed the whole 'plan' he had set up. Everything works just fine now-- with no help from the professionals, not that I didn't try.
I’m impressed for what you have done. Good job.
Reply to Tricky (to me at least) 4-way switch problem in the UK Electrical Forum area at ElectriciansForums.net
I know this is probably very simple for a lot of you, but I just can't get it to work right right. I've been close, but no cigar. I disconnected...
Hi All, Pretty comfortable with wiring lighting until I came across needing to install 2 way dimming with a Retractive switch. I didn’t even know...
