Discuss Triton Bewitch Electric Shower 9'5kw, Constantly going hot to cold in the DIY Electrical Advice area at ElectriciansForums.net
I have a Triton Bewitch Electric 9.5kw shower, which keeps going from hot to cold every 20 seconds or so, it has three heat settings buttons with led lights on the front panel, when it goes from hot to cold you hear a click noise and the led lights show it's going from hot then to cold, the water flow rate is fine, i removed the shower head to make sure no build up or blockage there, i've tested the thermal cut out with a meter and by putting the live wire to the other side of thermal switch but still has the same problem, i've turned temp down to minimum but still without any success, as the flow of water is fine and thermal switch is not faulty has anyone got any ideas what else would cause this problem i could test.
Reply to Triton Bewitch Electric Shower 9'5kw, Constantly going hot to cold in the DIY Electrical Advice area at ElectriciansForums.net
Hi My Triton electric shower which is around 7 years old is gushing water from the bottom of the unit, should I call an electrician or a plumber...
Hi All,
My triton martinique shower suddenly became only lukewarm, i get my trusty multimeter out and sure enough, one of the heater coils has...
Sorry not a question rather a solve.I had no hot water from my electric shower.I was going to buy a new one as it is quite old anyway.When I...
Bit of a strange one ive been told by everyone ive called
had a triton t70xr 8.5kw
The water started running cold like the tco kicked in
after a...
Hi,
We are renting and have a electric shower downstairs (extension) - a 9.5kW Triton T80Z fast-fit electric shower as well as a combi boiler...
