Discuss TV wiring for 9x new build flats in the UK Electrical Forum area at ElectriciansForums.net
J.C.E
Afternoon
Just so I can agree with the builder- can I get advise on following.
What wiring I need per flat to allow for sky and standard tv aerial
So per TV position in each flat (average flat 3x TV positions- 2x WF100 cables to flats utility cupboard- so if 3x TVs- there will be 6x WF100S in the utility cupboard of the flat
Then from the flat utility cupboard- take another 2x WF100 cables to the loft where the dish and aerials will be close
Will this be adequate and allow for sky and standard tv aerial
If they want to also wire for Virgin Media- just take 1x virgin media cable from the ground floor riser cupboard to each flats main TV
Then get virgin engineer to wire from road into ground intake?
Cheers
Take a twin sat from communal area to main tv position then take a single from main tv position to flats utility cupboard and run a single out to each extra position within flat. Do the same for each flat and run 5 singles from communal area to dish/aerial position. At the main tv point in the flat you’ll have a quadplex plate which the twin sat will connect to, then have a coax point which the single will connect to (you can get this all on one 2 g plate with modules). This single acts a return to the utility cupboard which will have a little splitter to connect the coaxes that go out to the extra points within flat. To make it work at the main tv point you plug a little 2 way splitter into the tv port on quadplex, plug the tv into the splitter and also plug the return into the splitter. Sky Q can work on a single coax and there has to me a special multi switch for this to work which is about £800. I normally wire it this way and allow £200 per flat for the tv guy to come in and do the connections in each flat, the communal and also put a dish and aerial up....He supply’s all the gear for this including any multi switches etc. There’s a myth that q doesn’t work properly with quadplex plate but that’s bollox, you just need the correct multi switch etc.
Reply to TV wiring for 9x new build flats in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone, I am currently in the process of estimating the electrical demand for a new construction development that will consist of an...
  • Locked
5K
Evening all Starting two new builds tomorrow and just wanted to check what other people do with regards the TV and DATA Its a new builder who i...
5K
1200mm is the max socket outlet height in new build property so what's the score with putting a socket at a height where a wall mounted tv will be...
14K
Hi Guys, First time posting but I've been commissioned with essentially running new cables from the head to 5 flats, due to the ground floor...
