Discuss Two versions of lighting wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I'd vote for do what suits. Not the end of the world if they're done differently.
don't mention suits. they are the bane of our lives, always interfering, think they know it all, when their knowledge only comes out of a computer, or a "meeting".
Am I right in thinking it isn't the best idea to wire feeds to switch in one room then to the light fitting in another in a domestic new build
Quite offten a method used by Clarkson Evans when I worked there.
T&E from CU to first light then 3core to the switch the T&E to the next room light then 3core to switch etc.
Using this way meant that you got a permanent live & neutral at the light & switch. Here's a quick drawing to show, CPC's have ommitted.
What was it like working for C.E.
I didn't have an issue with the long hours, hard work, quick pace or the in-house EAL training. Had other concerns.
I've recently seen a C.E. install in an expensive new build house, garage fed in 1.5 SWA from a SFCU in the house, that can be acceptable but the actual surface wiring in the garage is rough, awful clipping and I'd say it was very much rushed/thrown in without any pride in the job at all.
More than 2, don't forget the JB system , yes still nothing wrong with it, if it a accessible. ( got to say that load of rubbish)
Still plenty of RB4's out there too. It was good system really and maybe may make a comeback. A modern version. Loop in method is a pain in anything but a pendant and wifi controlled switches like to a take up a fair bit of back box depth.
Apparently a team of three guys, 1st fix 2 houses a day. If that's true, That's going some!! Quality would obvs take a hit.
Reply to Two versions of lighting wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Can a domestic consumer unit feed another consumer unit, via the Main Switch. Details are: domestic property with 100A single phase supply...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
Hi, I'm currently in my year of my apprenticeship looking for some help with the 2 plate method (feeding the switch). I understand it up to the...
