Discuss UFH thermostat feed what size cable? in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
B1gSte
Hi all.
I’m just planning out my electrics before boarding the new en suite.
Can someone verify.
Should a fused spur come directly from a socket or can I break in to a single cable using a Wago box? Also is 2.5mm2 cable ok to the thermostat?
I’m not making the connections, I will be employing an electrician at a later date. Just don’t want to get the wall boards in to find I’ve forgotten something later.
Thanks.
As above, doing the job safely is not just about making good connections. You need to find out the specs of the UFH and work out what the power requirements are. You then need to find out if an existing circuit is suitable, UFH could require a dedicated circuit depending on load. You also need to ensure all cables are suitibly protected and/or run in prescribed zones. It eould be best to get an electrican in now, to determine all of this, before floors and walls are fitted.
Thanks for your replies. It is a small 300W heating mat for 1.5m2. I have no intention of connecting anything. All I want to know at this moment in time is if I need to run a cable into a dry lining box on the outside of the en-suite, long enough to reach the nearest socket. Or can it be run to the nearest ring main cable and broken into at a later date. Thanks.
Edit: the room below has no ceiling yet so is accessible but I need to get the wall on and tiled.
i would use 1.5mm cable from the nearest socket location. then the sparks can fit a FCU to feed the ufh.
make sure cable runs vertically down from stat. position, not diagonal.
Reply to UFH thermostat feed what size cable? in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
I’ve recently moved into house and had an electrician out to install some new lights and shaver point in an en-suite. Problem is that the house is...
So a quick catch up so you can get an idea… I was asked to do a job for another electrician, as he is too busy. I’m busy myself but said I’d...
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
Hi all looking for some advice as a non sparky , be gentle :) To be clear I wont be doing the work myself , just want to be better informed. I...
