Search the forum,
Discuss Underfloor Heating Advice on installation in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hello,
New to the forums, I don't know if anyone is able to help me or give me some advice or tips (I'm not an electrician).
Me and my partner are buying a new build home and we wanted to fit underfloor heating downstairs, we have worked out it will be approx 15sqm of matting 100w matting, I believe this will mean wen it's on it will be consuming 1500 watts? My question is this, when we hire an electrician to connect it up, will he be able to simply be able to wire a switched spur from a double socket nearby or will a new ring need to be wired in? My partner is having nightmares that loads of holes will need to be made in our new walls if a new ring needs to be installed and our builder won't change what is set on the plans. I've counted 8 double sockets in total in the lounge / kitchen area but unsure if they are one separate rings (Not sure if this is relevant).
My 2nd questions, which I know is really hard to answer but I'll ask anyway, how much would I expect to pay to have an electrician come out and do the work (Fitting a switched spur from a double socket - if possible - and connecting the underfloor heating system to it?
Any other tips or things to look our for?
Thank You!
To answer your second question.. in my view it depends largely on how far you are looking at putting the SFCU away from the existing socket. If it's next door to the socket and the wall is board, then it could be as little as an hour.
If the mat is 100w per sq m, and the total load is 1500w, then this is roughly 7A, so it should be fine to run off an existing ring circuit. My personal preference would be to run a new circuit for it just to keep it separated from the sockets.
At some point in the future, it is likely to develop a fault that could trip the RCD protecting the circuit it's connected to. If thats the same circuit as say your fridge/freezer and you're away for the weekend, you may come back to a puddle. Just something to think about because they do go wrong.
My advice is don't get underfloor heating, when it breaks down, and it will break down it will be a nightmare to repair
I don't agree with that, I have installed it before, some of it nearly 10 years old and it is still going strong, that said I don't like it.
I've only Installed it one a couple of occasions, but I've been called out to it not working on many!
Dont like the stuff myself. If it goes wrong then as others have said it can be a right pain to sort out.
However, one option could be to use one of the double sockets and utilising frid modules, swap out the socket for the a switch, fuse and outlet module.
Downside you loose a double socket, but benefit is that it minimises cutting into the wall for a seperate fcu.
Thanks for the replies, I didn't realise they went wrong so often. My parents have a small 1sqm patch on their ensuite and they have never had a problem. The only reason we wanted it was as the kitchen and lounge is all open plan, we wanted tiles, and they are freezing to stand on so just wanted something to keep them comfy to walk on, we are not looking to actually use it as a primary heating source. I like the idea of taking out a socket and using the space, I don't think we have any plans to have anything plugged into the socket we are looking to put the spur next to.
What normally goes wrong with them? Just poor quality parts / bad fitting? Or do they just go bad?
Oh I see, you believe a couple of posters, okay if I tell you to jump off a bridge and 20 others say no would you? lol
So .............. be VERY careful if you do proceed ........ make sure the spark supplies the kit, he tests the mat out of the box, when its been laid and again after its been tiled ................... miss out any of these steps and you could be rapping the floor up again and / or having an argument about how's fault it it. Many manufacturers won't honor guarantees if you don't test at all these steps
PLUS .......... how big is the area? How many mats are you planning on? and how many controllers?
Tread carefully is my advice - and then don't be alarmed when your lecky bills go up significantly...
Reply to Underfloor Heating Advice on installation in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
