Discuss Unimaginable amount of electrical noise after plugging PC Power Supply in the Electrical Forum area at ElectriciansForums.net
Hey everyone, lately I've been trying almost everything to reduce the electrical noise over my Be Quiet Straight Power 11 850W 80+ Platinum PSU which exceeds 2000~ mV or 'onlygodknows' how much it goes up, just right after powering up my pc. How could possibly an premium quality such as Be Quiet which has Platinum efficiency rating of 90+of guaranteed power output to create such huge amount of electrical noise? I've even called electricians and they doesn't seem to be anything wrong at all.
This always happens after powering up my pc the noise goes beyond this universe, it's just so frustrating that you can't even enjoy your own pc due to really sluggish performance of the new pc I've got.|
P.s: My house has really low voltage which is separated on two "phase" while one phase is kinda strong being 210V~ and the other one is cut off on half down to 170V~. Also I even tried an 3500VA (also even 5500VA) Automatic voltage regulator) but it doesn't even make any difference in the noise. I'm not fully sure the house's voltage is the problem as moving to another house wouldn't be my best option since this is my new house from the previous owner. The whole house's electrical system is so weird as even the previous owner had a fire blast over the Voltage Regulator he was using for the washing machine and he had shorts everywhere causing fire probably as I could see in the house's black marks.
Now the line is separated in two 'phases' cause of the accident they had before which is more safe but worse at outputting voltage. Not to forget the line cable that supplies my house is also separated to another house that supplies them as well that goes down to the left side of my house; there is a box that contains 3 old "ceramic breakers" which supplies the other house there but the electrician said that it doesn't matter. I'm out of ideas on how to fix all this horrifical noises the PC's Power Supply creates, some said that they bought those filters to clean EMI noise but turned back as it was before for a couple days, so I'm not yet sure if I should try them as I can't return back since I am on Europe and have to order on US, as we don't have those things around here.
When you say that you have 2000mV of electrical noise, how are you measuring that and what is that voltage between?
Might also be useful to know which country you are in as 120v split phase is rather American, but you mention you need parts in Europe in the end.
With the words "fire " "black marks" and "shorts everywhere", pictures could keep us entertaines if you have any you'd like to share! (And of course, perhaps you should get an electrician to test all that before your house burns to the ground)
OP
Thanks for the reply.
I used the GreenWave Broadband EMI meter to measure the noise and it just shows "2--- mV" straight out after powering up my pc, also the noise is holy deep based on the speaker of the EMI Meter that I could hear. Also yeah, I'm located at Southeast of Europe basically on Kosovo.
dogbob
There is a high probability that the PC power supply is defective.
Can you take the PC and noise meter to a friends, just to rule out your particular house's wiring & supply issues?
OP
Yes I did. That's the first thing I had to try but unfortunately it was the same, it showed "2--- mV" but of course it was a little bit stable cause of decent voltage which really didn't make any difference to the noise, one thing it did was that it got that "flow" of the wiring of that house I tried which lasted for a few days then it came back as it was without affecting the noise. Also last December the electricity around here was terribly bad, possibly due to overload of the electricity system around here, in just that time I bought that PSU to replace my old Delta OEM 300W PSU but the performance was going smoothly for 2 days, after that it never was the same.
OP
aaaaaaaaaa
Sorry, missed that one. I can't really show them at this moment but this was fixed by the previous owner as the electrician said it is split into two "phase" which made more safe against such fire accidents. By that I meant it still prolly something not right either way it's the worst electricity I've ever got since I moved. Yesterday I had the electrician and he says everything seems pretty good and nothing's wrong except for the "split" part that potentially could be dangerous to put just in "one". I had also the electricity company's workers but that was 2 years ago which there was a storm hit somewhere and it shorted out most of the thing in my house but they fixed that. I don't really have any rod installed except the metal one's I think as everyone which seems terrible if there's in question device performance.
pc1966
Some of eastern Europe was typically on a low current (30A-ish) 3-phase supply, not your typical 60-100A single phase for UK, but I don't know if that applies here.
@darKz_ can you post a picture of your consumer unit (distribution board, fuse box) and related incoming power / billing meter arrangement?
My own suspicion when 'noise' is mentioned is always the earth/CPC arrangement as most folks are not aware of a fault until it goes horribly wrong (and then they might be dead so say nothing more). But if it is a 3-phase supply then a poor neutral connection could cause all sorts of strange voltage fluctuations, even to the extent of destroying electronic devices, etc.
Edit: Also I remember @Lucien Nunes pointing out they (eastern EU / former Soviet block) can be on a TN-C supply so any neutral faults are also earth faults!
Reply to Unimaginable amount of electrical noise after plugging PC Power Supply in the Electrical Forum area at ElectriciansForums.net
Electrical News from Electricians Forums and Friends
E
Want to become a qualified electrician? Look carefully at the training courses on offer to avoid wasting time and money, is the advice in a new campaign from electrical industry body The Electrotechnical Skills Partnership (TESP). With thousands of searches each year on terms such as...
6K
Marty92
Dan
You can now link your account with social media by going to the following page. https://www.electriciansforums.net/account/connected-accounts/ We had this feature some time ago but I removed it when Facebook was found to be selling the data they collected without informing the users of what...
Dan
Dan
There was a dodgy advert, typical clickbait, showing "how to save 90% on your electricity bill" which was not the case and it was actually showing some dangerous wiring tactics. Read the actual threads here:- What should be the code for this - C2 or C3 -...
8K
Jurassic Sparks
Jurassic Sparks
James
The Go Plus hot tub is being recalled because you could get electrocuted taking a dip, according to press releases from the Chartered Trading Standards Institute (CTSI). An Amazon spokesperson said: "Safety is a top priority at Amazon. "We require all products offered in our store to comply...
Dave Appleby
Dan
Posted on behalf of @CKI:C.K-Tools Carl Kammerling International Ltd, also known to as ‘CKI’, are the company behind the C.K Tools brand. Founded in Germany in 1904 and with roots stretching back to 1790, we provide a wide range of hand tools, tool storage, power tool accessories and...
4K
telectrix
telectrix
New Posts (Please Reply)
Search Forum
