Discuss Upgrade to three phase supply in the UK Electrical Forum area at ElectriciansForums.net
M
MichaelS
Hi all,
Newbie here with no electrical experience so please be gentle! :blush:
I am currently refurbishing my basement flat and during this we have discovered that the supply to the four flats is single phase. I have been told this is unsafe and insufficient for the four flats. U.K. Power networks initially came over and the engineer couldn't believe how it was setup, four separate metres on a single phase and was amazed that there had been no burnouts.
My questions:
Is this unsafe and does it need to be changed?
Who is responsible for upgrading and paying for the upgrade?
If it is the freeholders, is there a way to make this a legal requirement?
Is there a way to make either Uk Power or the electricity companies to do it?
Many thanks
Michael
Is that not a 3 phase feed that is split per flat then?
Two days running and a head with four fuses. Must admit looks a bit Heath Robinson with the three left fuses connected from the original one but they could be soundly connected. Whether it is dangerous or not cannot be judged by looking at a picture. Who has told you it is unsafe.
You need to swap places with the people who have this already installed: Domestic Supply ? - http://www.electriciansforums.co.uk/threads/domestic-supply.118210/ :)
It's up to the DNO whether it's considered safe, the applicable regs are different to those for the electrical installation itself. Based on what I wrote in that thread, it's probably not recommended practice, depending on how the fuses are physically fitted and the size of the service cable. The specific fact of being single-phase is not in itself dangerous.
Surely, the only problem is if the supplier's cable is of insufficient current rating for the load. If it fails, then it's up to the supplier to replace it.
If the heating and hot water for the flats is by gas, then I doubt that there will be a problem. If heating is electric, then maybe a review of the situation is required.
Reply to Upgrade to three phase supply in the UK Electrical Forum area at ElectriciansForums.net
Hello, I'm new to this forum, we are in the process of converting into 12 flats all electric, no gas incl. heating, showers etc. An electrician...
We are refurbishing an empty commercial building at the minute and I don't do commercial stuff day in day out so not entirely clued up on...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
(Thought I'd already poost this Q, but I cant see it, so I'll try again) We have some work going on in one of our buildings atm. On of the chaps...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
