Some LED / dimmer combinations are just barely stable. Any slight change in the supply characteristics starts them flickering, and this might be what is happening here. The transformer(s) are causing a teeny bit of waveform distortion that normally wouldn't be an issue, but it is disrupting a marginally incompatible dimmer. There's no reason why a transformer, in theory, should cause a problem, but some commercial units designed down to a price, especially if they are really made for the 220V or 60Hz market, can pull a rather distorted waveform if your mains voltage is on the high side.
I would venture an opinion that some transformers wouldn't cause this effect, but the cure probably lies in finding a more tolerant LED / dimmerr combination, not least because you might find other types of equipment that might trigger the same behaviour in the future.
