Discuss used copper wire cable cutter in the For Sale and Wanted Forum area at ElectriciansForums.net
C
Copper Wire Stripper
cuts up to 50mm on hydraulics £190.00 ex demo
call me on 07872102395
Reply to used copper wire cable cutter in the For Sale and Wanted Forum area at ElectriciansForums.net
  • Locked
My house was built in the 1930s, The fuse in my service cut out is 60Amp and the wire coming from the street has a 16mm2 copper core(easy to see...
Hi, The shower pull chord switch has snapped at my mom’s home and having unscrewed the switch I discovered a horror show(see pic). So I’ve had...
So this is 1st floor maisonnette with concrete floor, 16mm2 single insulated tails coming from dual cut out on ground floor, through steel...
Does anyone know what the cable in the picture is called? Or anything about it? Labelling on the outside is “E SPC Electric Cable 600/1000v” Its...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
