Discuss Using chimney as cable route? in the UK Electrical Forum area at ElectriciansForums.net
littlespark
Supporter
Patron
I'm going to look at a job on Monday and I'm not sure if there's any regulations that I need to think about.
The job is to install a wall mounted TV on a chimney breast, with the sky box and bluray player installed in the fireplace.
Now obviously the fire isn't in use, and the homeowners are utilising a wasted space.
My thought was to drill straight through the brickwork into the chimney and drop the cables down the void, possibly in pvc conduit. Alternatively, cut a channel into the front of the wall.
Is there any building regs to say I cant drill through it?
I also need to find power for inside the fireplace, so the whole job might not happen if there's no socket nearby.
I could run surface trunking up the front, but that's not going to look very professional.
If the route is ok, my plan was to find a nearby socket on the rfc, spur off through an sfu and run a radial to the fireplace, double socket, or even 2 x doubles there for the equipment. Then run up through the void, coming out behind where the TV will be positioned with a single socket on a dual box, with a brush plate next to it for all the AV cables.
The homeowner will be decorating after, and building shelves inside the fireplace.
I think i'll leave him to mount the TV bracket. Knowing him, it'll be 50" TV at least
For all the extra cost I'd put a double socket behind the TV as well. The likes of firesticks and roku sticks are ever improving so who knows what they will plug into hdmi ports in time to come
I got some very good advice on here when I installed a wall-mounted TV...and the brush plates were an excellent choice. I would say that the ones from TLC were far superior to those from Screwfix. The 38mm conduit easily took 2 HDMI, a satellite cable, a coax cable and an ethernet, with room to spare, and the usual 16mm for the power supply. For what it's worth, I bought the HDMI cables from Currys, and opted for the flat ones...they are very easy to install, and take up little space, plus the actual plugs are neat, not too bulky. Fully agree with Murdoch-get client to install the TV bracket beforehand, so you know where everything is to fit. As advised, I used a double back-box, with the media cables to one side, took out the 2 cutouts and sawed the rest out to make a rectangular hole, with grommet strip.
I fitted a "divider" between the 2 sides of the back-box, keeping separation between the media cables and the power supply. Probably not really necessary.
Just a thought, but if this a semidetached and an old house (Victorian etc) then the fires from this and next door will use the same stack. The bricks inside the stack that separate the flues are usually loosely stacked with bits of mortar faking out. This would compromise the separation of each flue. Then if next door lit a fire that didn’t have a steel liner the result could be dangerous gasses finding a path in to the room. Just something to be aware of.
I think it is a semi... but i'll see tomorrow. I'll find out from the homeowner how long their fire has been removed for. There will be a smell if next door are still using theirs, even from a few months back.
I've worked in attics before where next doors fire smoke was seeping through the walls. No one knew until we were in rewiring. That all had to be sorted before we could go back in.
I'm hoping they haven't just blocked the chimney just above the fireplace so I cant get up the void.
Surface trunking might be my (their) only option.
Reply to Using chimney as cable route? in the UK Electrical Forum area at ElectriciansForums.net
Evening all.. I have just been core drilling a 105mm hole for an extractor fan in a bathroom wall. I had a good look around on my pre works visit...
Hi All I would appreciate some help with a few questions here regarding cables sizing, I'm using the latest 18th edition, amendment 2. Q1...
An odd question granted but bear with me. I've got to extend a radial circuit in a community centre to fit a new hand dryer in the toilets, but I...
Hi all, Our sparky has carried out first fix, twin and earth cables clipped to the block walls of our extension routed to each back box. His...
4K
