514.4.2
Single core cables that are coloured green/yellow throughout their length shall only be used as a protective conductor and shall not be overmarked at their terminations,except as permitted by reg 514.4.3
It then goes on to say,and by the way the green/yellow in multi core cables "can" be oversleeved so crack on
Sorry about the last line that was a downright lie
The reason i included that is to try and show that there is no problem deciding that the actual reg does not include multi core cables
It is no problem because multi core is not included
(If it was the case that multi core is included,then it would not specifically mention, in isolation, single core cables green/yellow throughout their length)
Where is this grey area or doubt that has been talked about,its as clear as night and day
You can colour code a multi core green/yellow to another colour and you break no reg
I have never and will never do this,but if it was found it is permitted
