Search the forum,
Discuss Valliant 837 Boiler Wiring? in the Central Heating Systems area at ElectriciansForums.net
M
munch88
Hi there.
I have very little experience wiring boilers and will be required to wire a Valliant 837 soon with an external thermostat (not sure on model)
I understand the thermostat controller can be wired as 24v or 230v.
On the wiring diagram, there is a connecton called RT (for 230v) which says it's for the thermostat. So does the thermostat controller require a permanent live and neutral from the load side of the FCU and a connection from terminal RT?
For 24v, does the thermostat just require a 2 core from the connections labelled as 24 RT?
Much appreciated
is this the correct diagram munch88?
If wiring into the 24v input it is just 2 cables from the thermostat output into the 24v DC room thermostat input taking out the link, if 230v then it's just 1 into the 230v AC room thermostat connection, the bottom one, it's just a switch wire from thermostat, leave the 24v link in.
Reply to Valliant 837 Boiler Wiring? in the Central Heating Systems area at ElectriciansForums.net
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
Hi - we have an inline heater for a vent system that appears to always be on. I believe the electrician may have wired it incorrectly with only a...
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
