Discuss Veritas alarm problems in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all,
Recently my Veritas alarm stopped working (I don’t know the model sorry!), it turns out the battery blew so I’ve now replaced it but it seems like the whole thing has factory reset. When I power it back up the unit gives single beeps that won’t silence using my code. If I trigger a door sensor the alarm blasts unless I unplug everything again. Can anyone guide me on reconfiguration or some basic troubleshooting?
if it'd reverted to factory settings, the codes are 1234 and 4321. one is user, other is engineer. can't remember which for certain but think 1234 is engineer.
If it’s one of the Texacom veritable range, 4321 is the default users code and 1234 is the engineers as long as the installation company hasn’t changed it and locked the default off the panel. If 4321 doesn’t work then take the battery out and disconnect mains supply then re energise the mains and tap the spring on the circuit board this will default the panel to 1234 however as above if the engineers code is locked in you won’t be able to access the program functions
Reply to Veritas alarm problems in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi, I have a veritas R8 alarm and corresponding keypad. Recently a powercut caused one of my keypads to stop working. I replaced the battery in...
Hi all, Requesting your help please! I know this is an old system but has been working amazingly for 7 years! I had an engineer out who done a...
Hi, just wondering if anyone could help me. I’ve just installed a texecom Veritas alarm in my garage at home and can’t seem to get rid of the...
The big stately home I’ve been working in has an EMS 5096 alarm system with over 100 detectors and 3 (that I know of) panels. All detectors are...
Morning All Qualified electrician, usually stay away from alarms but my friends parents have issues. Texacom Vertas panel, not worked for over 3...
