Discuss Vokera Linea 24 combi boiler - Hive wiring help in the Central Heating Systems area at ElectriciansForums.net
I'm trying to install a hive thermostat. I was able to get the hive receiver hooked up but I think I've made a mistake with the wiring as the heating will stay on continuously.
Can anyone tell me what needs connected to what?
I've attached the boiler board (It only has the old timer connected in the picture) and the two diagrams for hive/boiler.
Cheers
Reply to Vokera Linea 24 combi boiler - Hive wiring help in the Central Heating Systems area at ElectriciansForums.net
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
hi need help with wiring this. basically new build with combi boiler, unvented cylinder with dual channel hive ive attached pics with the wiring...
6K
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
Hello, I'm in the process of changing my wired remeha thermostat with the wireless hive mini, I've had a look at the manual and believe I have...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
