Discuss voltage device like rcd in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
went to look at we job last night and its an out building out back of the house..
the guy/doctor wants two way switching on his lights and an extra socket on one side of shed. no probs.
there is a small board out there which has a voltage device in front of board , when you push it trips rcd in house.
im thinking of changing to an upfront rcd 30mA which will be two in series.. i know this is a no no but seems a better option than just take it out.... all new cables willl be surface mounted so i could just leave it in and use rcd /sockets
anything to say conduit monkeys................
I had a similar situation, I used a 25A/30mA RCD upfront on the additional board, @ 1x local RCD only trips and @5 x parent RCD protection operates, and that is what you should aim for, use quality products and you'll be cushty, and bin the ECLB
Pict
there's 3 x 3036 b0ards around the house and what the last person has done is just put 30mA rcd at front, to controll all boards and left eclb in and where the shed is maybe 40m away
Bit of a head scatcher then, if the upfront RCd is out of henly's can you tail out of there via your own OPD set up then a new board in the shed as long as the cable down to it pass IR and cont
Pict
Reply to voltage device like rcd in the UK Electrical Forum area at ElectriciansForums.net
Doing a lot of EICRs at the moment and have came across what I'm sure is a common enough problem. In an off grid rural cottage I have a TT system...
Have an existing old client with what's best described as a sprawling small-holding of a property. There's an armoured external supply which...
