I got a couple of good quality padded camera-kit bags from the charity shop, a fiver each. 1 holds my multitool and impact driver and has numerous zipped compartments for drill bits, blades and other accessories. I actually went into the shop to drop off some stuff, and came out with the 2 bags, a lob wedge and a camera tripod...
The tripod was as new, and retails around £120, but it was priced at £19.99, so irresistible really. Of course it fits my cameras, but also useful for laser level!
The lob wedge was £5, and has improved my golf immeasurably...
by which I mean you couldn't measure any improvement at all...
I’m pretty certain some people were selling cases on eBay when I found that Martindale.
Though to be honest, this one might be better as it comes with voltage tester, proving unit and case:
Seems a lot for a case. Maybe it’s good quality. I’m unsure about buying used test equipment and it was open to offers but you would only save a fiver. There is a brand new socket and see on Amazon £115. With a case and everything. I’m in two minds as there is also that Megger for £108.
That Martindale one that you found originally seems good for £60 and then a case at £21. So it’s not too bad. But I don’t know if it’s worth paying the extra and getting the socket and see from Amazon or the Megger. Does the Megger have additional functions? As I’ve seen the Martindale in college when we done some safe isolation. Looked good.
What other functions are you looking for? it's a case for your tester and proving unit.
The person selling the Martindale has said he will except £50. Including buying a case and postage in total is £79. Good buy?
Or you could buy the one with a case for £55 + £10 postage.
That one’s open to offers as well.
All these things do is tell you whether something is live or not, and which voltage band it’s in.
The proving units are just something for you to check your tester is still working before and after use.
I understand what they are for, I am just weighing up pros and cons and whether to buy a nearly new, one from eBay or an online retailer.
I’m just saying that they all do the same, whichever manufacturer you purchase from.
Myself, I have a Fluke T3 which I’ve had for over 15 years.
It needs batteries to function, but not only does it test voltage, it also tests for continuity.
Don’t think it’s classed as an ‘approved tester’, but I’m happy with it.
Never owned a proving unit, only ever used one in a classroom.
If I want to verify my tester is working, I test a known live circuit.
As for buying new or second hand, these sorts of test equipment are pretty robust.
The Martindale unit has been around for years and is known for being pretty robust and reliable.
Socket and See is quite a new company, though I did quite like their basic socket tester when it first came out.
Bit wary of the later models with RCD testing.
Megger have been around for years and their MFTs and Insulation testers are well respected.
Not so sure about their voltage testers, never seen one until very recently.
Thanks, the Socket and See are new company It looks similar to the Martindale. I originally gravitated to the Megger, because of the reputation they have with MFT. I will do some research.
Ending up buying a socket and see kit with a case for £63 posted. Brand new too. Will see what it’s like when it arrives.
AHHHHH who on earth issued those permits ???????
I work at powerstations all over the UK. During outages some of the SAPS are very overworked and on occasions can miss something. As the permits always say, 'check for dead using an approved method before starting work'. it always makes sense!
RDB85
Trainee
Liverpool
Trainee Electrician
Voltage Indicator and Proving Unit
Electrical Tools and Products
RDB85,
ruston,
