Discuss Voltage Indicator Pens? in the Electrical Tools and Products area at ElectriciansForums.net
The alphatek ones are good but the light on them tends to have a life of its own.
So there rubbish then:eek: what good is a voltage indicator without a light ,as i said before i dont use them ,i dont trust them ,and doubt if i could find a fault with one.i cant understand why anyone needs one,its beond me ,i must be missing something:confused:
Not the light to indicate a live circuit but the small lamp on the other end of the stick, as a voltage indicator its no more or less reliable than any other brand and while i would not use it to fully verify that a circuit is dead they are a valuable tool if used for identification.
ever thought of using it to test switch lines or test cable to c if it is broken between one point to the next u can also if you r good you can hold it on a fuse spur and switch it on/off and u can c ifpower reaching it without removing cover nobody said u should trust them but if used correct and on as a basic check then there should b no problems
Reply to Voltage Indicator Pens? in the Electrical Tools and Products area at ElectriciansForums.net
Today I went to fix a minor loose screw on something and after switching off, etc, got out my Martindale VT12 continuity & voltage tester and...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips. For some chips it is...
Am absolutely gutted, my Fluke 1587 insulation tester appears it's had an unknown fatal incident. I was doing some testing a few days ago and was...
Why is this still a thing, just done a quick calculation with the TLC volt drop calculator and if its a non lighting circuit the recommended size...
