Discuss Warming up cool white LED in the Industrial Electricians' Talk area at ElectriciansForums.net
Deleted member 9648
We have an issue with some 30w LED floods we installed as uplighters. This was a bit of a rush job without a proper spec. The users are complaining that the lights are too 'cold' and have asked us to replace them with a warmer version. Fine, we could order warm white versions but there are a number of fittings, they are not going to pay the additional costs, and we don't want to bear them either as we provided what they asked for as far as we are concerned.
So does anyone know of a suitable self adhesive film which could be used to warm up the colour? As they are uplighters it would not show,and there would be minimal heat to affect it. Perhaps there is something like that in the theatrical lighting business?
Not used them myself but maybe worth a go before swapping fittings.
https://www.stagedepot.co.uk/lighting/gel-kits-accessories/kits/led-warm-gel-kit#horizontalTab1
Yes you can get lighting gel which changes the colour temperature of lamps
You are probably going to need CTO which is colour temperature orange it changes the kelvin of the light but when using any gels you do loose light level
Try these
Lee lighting filters
LEE Zircon - Longer life filters for LED
But it's expensive stuff 70 quid a roll
Would a sheet of it not be sufficient?
If you ask most suppliers they'll send you a swatch book for free.
Reply to Warming up cool white LED in the Industrial Electricians' Talk area at ElectriciansForums.net
Are you looking for the perfect light bulb for your project? If so, you may be wondering whether cool white or warm white is the best. In this...
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
I have the typical LED on Dimmer switch. All the lights flicker in my house are very inconsistent times. By let me clarify by saying all the...
We're in the UK, 240v lighting feed. We have replaced all the lights in our house with LED ceiling panels. These are pretty much the standard...
I am looking to install some 12v led strip lighting in my touring caravan. I want the option of warm white or cool white. Is it possible to not...
