Discuss Washing machine blowing electrics in the Electrical Appliances Forum area at ElectriciansForums.net
Thank you all for your replies. I will try plugging into a different socket tomorrow and see if it works!
Hi,just a thought,but make sure you pick a socket which is also RCD protected.
You already may have a machine,with a fault,so choosing a socket which is not protected by an RCD,may do two things,it may allow the machine to appear to be working,and dependent on the fault,allow the machine to become hazardous.
Just a tiny worry,if you were to plug that extension in to a garage socket which someone has wired straight to the power station
so you'r down in yam-yam land?
Thank you all for your help and advice....problem resolved with a new washing machine!
Hi, might be a late question since your problem happened a few years go.Thank you all for your help and advice....problem resolved with a new washing machine!
Did you plug your new washing machine to the same plug?
Reply to Washing machine blowing electrics in the Electrical Appliances Forum area at ElectriciansForums.net
