Discuss Washing machine blowing electrics in the Electrical Appliances Forum area at ElectriciansForums.net
Hello
Useless female here....
I'm not sure if I'm in the right place but I have a quick question I'm hoping an expert can help me with!
My washing machine keeps blowing the electrics, I've managed to empty it of the clothes but drum is full of water.
Does this mean I have a faulty washing machine or could it be the socket/plug or something else?!?
Hoping some kind electrician can help me!
Thank you
Do not use your washing machine !! when you say blowing the electrics do you mean trips the RCD ?
Do you have anything else plugged in or running when this happens how long has it been happening ?
Can you take a pic of your consumer unit and describe what is tripping (Don't use your washing machine)
Cheers
Hi
Yes I mean the rcd box.
I can't get a picture on just yet as I'm using my phone and it doesn't look like I can upload pic from my phone.
It's the switch for all of downstairs that goes. Every time I flicked it back up it fused again until I turned washing machine off at the fused spur socket then it stayed on. Only other things on...boiler and 2 Xbox upstairs.
Thanks for your reply.
Can you pull your washing machine out?
Take a pic of where it plugs in and surrounding area.
Has the washing machine or anything else leaked onto where it plugs in? Turn off the RCD (that you have circled) and see if the washing machine plug or socket it wet.
It sounds like your washing machine could be buggered.
Test: Put nothing in the washing machine and turn it on.
If it still trips then it looks like you may need a new washing machine. or get it fixed.
If its only a few yrs old and regardless of the warranty expiration date you should still be covered by your consumers rights act.
If you get it looked at and it is proven to be a failure of the washing machine through no fault of your own then get it repaired if just a cheap repair or if expensive then submit the engineers report to where ever you bought it stating your consumer rights in that it has failed before the expected life of said failed part, they will either have it repaired and reimburse you with any costs or they will pass it on to the manufacturers to deal with.
I assume it was brand new when bought and not reconditioned or 2nd hand?
Does it trip when just powered or at a certain part of the cycle IE when it should be draining the water, it is common for the pumps to fail and should be cost effective to repair.
Does resetting the program to off trip the rcd when powered if not then try putting it on to a drain cycle to see if that trips the rcd... if it trips regardless of the program been selected or not it could be the mains smoothing capacitor which are not that expensive to replace.. if the plug and flex look ok then you may need a engineer in but before you do that just try run it off an extension from another socket, this will rule out a fault with the socket like a trapped wire that only shows under load.
@Adam W - that would explain the washer not draining but been a pump it would just fill the sink then gravitate back into the washer or back up over the vertical washer waste pipe flooding the floor, also doesn't explain the rcd tripping which is the primary issue.
As I said I was just throwing ideas around really - rcd starts tripping the same time as most of the country freezes, and could well have something to do with a washing machine... Maybe the water is backing up and leaking into something... Maybe the bearings in the motor have gone.... Maybe there's snow thawing onto a light somewhere completely different and all this business with the washing machine is just a coincidence. I don't have all the answers.
which part of staffs. are you. i 'm in Stoke next week.
Reply to Washing machine blowing electrics in the Electrical Appliances Forum area at ElectriciansForums.net
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
Hello My dear old mother tried to clean the tiles in our utility room by using a damp rag and I think some water may have dripped into our plug...
4K
Hi everyone. The title should sound crazy enough, but it's what happening in my 72-years old home we've purchased 2 years ago. I found the crazy...
Hey all :-) Hope its chill that I'm here asking questions, I just inherited this old decrepit place in NSW (Australia) and went to wash my hands...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
