F
Fenny666
Hi. I'd be grateful if anyone can offer me some friendly advice please.
My washer stopped spinning and I discovered the fault to be a broken wire on the motor connector block on the washer side connector.
Here's a picture.
I took the motor out a while ago and cut the tiewrap that secured the cable but I made the mistake of not re-securing it. I think this caused the break due to excessive vibration. I think it's safest to assume the remaining wires are likely damaged also.
There's enough slack to trim the wires back and make the good the connections. I can't see how to remove the wires from the block though. This seems the obvious solution if it's doable.
Failing that, could I remove the connector and replace it with a suitable terminal block/connector?
Or, should I buy a replacement harness and replace that section?
Or something else?
Thanks for taking the time to read this and also many thanks in advance if you're able to offer me advice.
Cheers
Here's a picture.
Or something else?
Cheers
