Discuss Washing Machine broken wire. in the DIY Electrical Advice area at ElectriciansForums.net
Hi. I'd be grateful if anyone can offer me some friendly advice please.
My washer stopped spinning and I discovered the fault to be a broken wire on the motor connector block on the washer side connector.
I took the motor out a while ago and cut the tiewrap that secured the cable but I made the mistake of not re-securing it. I think this caused the break due to excessive vibration. I think it's safest to assume the remaining wires are likely damaged also.
There's enough slack to trim the wires back and make the good the connections. I can't see how to remove the wires from the block though. This seems the obvious solution if it's doable.
Failing that, could I remove the connector and replace it with a suitable terminal block/connector?
Or, should I buy a replacement harness and replace that section?
Or something else?
Thanks for taking the time to read this and also many thanks in advance if you're able to offer me advice.
Cheers
You can get tools which slide in either the front or the back of the block to release the individual connectors.
I imagine on that block, there should be a little cut out on the front where you should be able to poke a thin screwdriver down to release the connector.
A photo showing the front of the connector block would be good.
Reactions: DPG
As above, there will be a way of removing the female pin from the connector. Take a pic of the front, back and the other side of the connector and post them up.
Reactions: DPG
and a pic of the other half of the connector. if that has accessible wiring then wagos may be your easiest option.
Reactions: DPG
Hi again. First and foremost I'd like to say thanks for taking the time. It's very much appreciated.
Here are some better images of the connector numbered 1 to 5.
I've ordered a tool kit off Amazon similar to the one suggested that's available on Prime so should get it tomorrow. I've looked at the connector again and I'm still at loss. I'd be grateful for an idiots guide on how these tools manipulate this connector please.
(telectrix)It's difficult to get an image of the other connector without flipping the washer but I do know the wires are accessible. I've had a look at the Wagos connectors on screwfix. I'm guessing the 24A would be more than adequate?
Thanks again.
Cheers
Hmm. Looks like you might have to dismantle the connector body if you want to access the contacts. Likely to be some sort of snap fit to prise open. I also think that they may be IDCs, insulation displacement contacts, similar to Krone or Scotchlok.
If you're not confident, then replacing the wiring loom may be your best bet.
You also get a 10A plug together connector strip you could use to replace the entire plug. Not sure where it's available in the UK, maybe try e-bay...
Rather than mess about with the existing connector I would remove the connectors completely and, as mentioned above, replace with wagos or similar. Will be a more reliable fix in the long term, especially if you aren't used to working with those sorts of connectors.
agree. get some 2 port wago 221 type connectors. cut off existing plugs, 1 wire at a time and connect each pair.
Reactions: DPG
add to above. these wagos, if you never used before, are easily release able, and designed to make a good connection on fine stranded flex. just strip the wire in accordance with wago instructions, 10mm - 12mm. and 24 A is well adequate.
And send us a photo of it when you've done it! We promise not to be too critical
I have a feeling that the connector block plugs into the back of the motor, not into another connector block.
if it does, he's shafted.
Seems to be quite a lot of black dust, as if from smoke.
I thought the photo showed the two connectors involved and ssume they were both on a loom. But maybe it was all of the same one.
Hi all. Thanks again for all of your responses. I've been away for the weekend so not had chance to update.
The dust I think is just carbon off of the brushes. It's on it's third set.
I looked into what you suggested HandySparks about it being an IDC connector and I'm certain you are right. I tried in vain to find a replacement IDC connector but I gave up as I don't really know what I'm looking for and there's so many. I tried pulling it apart with 2 pairs of pliers, but I found the force I needed to apply was starting to crush the connector and it hadn't even budged. Is this typical or am I doing something wrong?
I also looked into the wago connectors. I found them on Screwfix but the 221's (lever type) they only had available in 32A as a 100 pack at £30.00. They do have some wago pushfit ones which are 24A and are £13ish. Would these be suitable also?
I've had another idea and would appreciate your thoughts. I've posted a couple of pics showing the male connector from the motor.
The wires on this side of the connector are fine. Could I cut off the female connector and crimp 'push on' connectors to the wires and use some heat shrink tubing and insert them directly to each of the pins on the male connector?
Once again thankyou for all your feedback and I look forward to your responses.
Cheers
wago 221's are the answer. sure you can get them in smaller quantities than 100. try here. £2.88 for 10.
Wago 221 Compact Lever Splicing Connector 4.00mm - 2 Pole - https://www.tlc-direct.co.uk/Products/WA412C.html?source=adwords&ad_position=1o2&ad_id=45425533757&placement=&kw=&network=g&matchtype=&ad_type=pla&product_id=WA412C&product_partition_id=174057596467&test=finalurl_v2&gclid=Cj0KCQjwvezZBRDkARIsADKQyPmw06Q8XTBPegkHQ2KIePHgSuTAinmkqfvllb47ub99pxkpaVKXY2gaAts9EALw_wcB
cutwire 1 at a time , twist the strands neatly. push fit wagos are no use for fine stranded cables. stripping length is approx. 12mm.and mate up to the corresponding wire on the other side. 32A load is fine.
Reactions: DPG
I think what I would do there, is cut the corresponding wire on the motor side connector and use a single 30A Wago or connector block just to reconnect the broken wire.
Then plug the multi connector block back in.
If any more break, just fix them individually.
now why didn'y i or anyone else think of that?
Reply to Washing Machine broken wire. in the DIY Electrical Advice area at ElectriciansForums.net
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
Friend of mines dryer machine has stopped working, 2 days out of warranty. I am trying to help theme out as money is tight for them however, I'm...
I have Curry's Essential tabletop dishwasher model CDWTT115 for nearly five years. Earlier this year my machine have stopped running during a wash...
Hello all, I’m looking for some advice regarding a recently broken MVHR unit in my flat, model Heatrae Sadia Advance. The unit is out of...
Hello My dear old mother tried to clean the tiles in our utility room by using a damp rag and I think some water may have dripped into our plug...
4K
