Discuss water flood in the Industrial Electricians' Talk area at ElectriciansForums.net
B
bluecallum
Can someone please advise on what to do,had a massive water leak in ceiling where there are alot of lights,what should i do before i switch the fuse back on,many regards
HA!! Done that myself a few times. Drop all downlights out of ceiling ie make as many holes in the ceiling as poss. Plasterboard takes a while to absorb water it would much rather run over it and out of a hole but if it sits on the board it will swell and burst. Wherever there i a poss of live V switch off. get rid of as much water as poss . Water will always follow the path of least resistance(don't we all)so get the damp out of the ceiling void asap. It's easy for me to say but keep calm, Know what you're trying to do and all will be fine
hi think same as above and u should probs do a continuity test on the down lights to see if the water has made a short on the terminals, if it has then try to dry thm/ leave in warm dry place for day or so then re-test if ok then fair enough re-use if not then its probs best to re-new the down lights. better safe than sorry ey!!
Reply to water flood in the Industrial Electricians' Talk area at ElectriciansForums.net
I want to buy two of the above for my property. I am on a budget. The property can get battered by driving rain, finding an outdoor LED flood...
I am never quite sure if I am doing too little or too much when someone has a flood and I am called in. The most recent example is a chap has had...
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
Wonder if anyone can help out, my experience in heating is minimal. So house I was working in had a circuit for the water heater, which went to a...
Hi All, I've bought a 12ft Catering Trailer that is mainly fitted with LPG Equipment, but Electrics are required for 1x Undercounter Fridge, 1x...
