Discuss What a mathematical error!!!! in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
I cannot believe I did this. I am almost obsessive with mathematical calculations. In fact, I actually try to be less obsessive as it takes so much time and mental exhaustion to be exactly correct to the mm/cm/m.
I had to measure a long run to a new sub DB that I was putting in. It was an awkward run, twisty and turny in a barn, up and down, and into a field.
It took a lot of will power but I decided for the first time ever to just 'pace it out', rather measure it. I felt really uncomfortable as the OCD was kicking in, (but also a tiny bit brazen which felt good 😁) but I did it. An 80m (paced out) length. I then added on 10% and purchased 88m of cable.
Went to the job yesterday, spent 2 hours getting the 88m of heavy SWA in to the twisty turny, high up places........
I was short.....
by 37m!!!!!?? 😳
That's ridiculous, I have never been short in my life. Literally never. I always have excess. Too much excess, I have sooo many off cuts of SWA ready for scrapping.
37m!!??
Half a day spent getting the extra cable, running it and joining it.
I will never pace a job again. I shall revert back to my mathematical OCD and revel in it, rather than fight against it 😔
What on earth went wrong!!!??? 😖
I cannot believe I did this. I am almost obsessive with mathematical calculations. In fact, I actually try to be less obsessive as it takes so much time to be exactly correct to the mm/cm/m
I was short.....
by 37m!!!!!?? 😳
That's ridiculous, I have never been short in my life. Literally never. I always have excess. Too much excess.
37m!!??
Did you have a tight skirt on? So you couldn't get as much of a stride.
When I started I used to do that pace it out, sometimes 2-3 times just to make sure, I always ended up with way too much cable, and sometimes oversize due to calculating the Volt drop on the cable that was too long!
I bought a trundle wheel a 50m tape measure and a 30m laser measure, use them daily and the few sets of them I have had over the years have saved me loads of stress and probably more than paid for them!
Reply to What a mathematical error!!!! in the UK Electrical Forum area at ElectriciansForums.net
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
