sythai
Hi Chaps
I've got a Wiha torque driver but only came with couple of bits (below)... none of which fit 'outgoing side' of Contactum RCBO's.
Anyone know what size I'd need please ? So can order up
Tried their technical but no one there until next week 🙈
Cheers Sy
If those aren't fitting correctly, it may be SL/PH1 or SL/PH2
Markings on the screw heads should indicate whether it is Pozi or Philips.
Is it just a little tight for the SL/PZ2? Maybe the plastic just needs worn away a little?
I’ve got same bits for my wera torque, and not had an issue.
I actually snapped an SL/PZ1 using it in a terminal which I thought the hole was too small for the bigger size.
These are the ones.... smaller one for outgoing side
PZs1 and PZs2
Not uncommon to see #1 used on outgoing terminals. Have seen them also used on earth & neutral busbars. Bit of a pain that manufacturers can't use a common head on all terminals.
I wouldn't mind seeing Torx20 used for terminals in a board. Have been fitting hobs and cookers of late which all have Torx20 for connection screws and are lovely. Or just go back to flat head screws
I'd like to see Scrulox on everything.
sythai
Devon, United Kingdom
What torque bit.... Contactum rcbo
Electrical Tools and Products
sythai,
littlespark,
