T
Tester Steve
Help!! Doing a rewire and the customer would like a modern, preferably white, rocker switch 'one above the other' as in the piccy. Searched as far as I can, but cant find anything. Any ideas??
Many thanks,
Steve.
I've seen them on a website that do a whole range of old style switches, when I find it I'll post a link
can
Yep, side by side, but none above each other!! Ta anyway!
Steve.
it looks like the switch can held on with the threaded ring on the front, if this is the case you should be able to rotate the switch 90 Deg and get what you want. I would give them a ring and see if this is the case.
Theres a place in shrewsbury called the period house shop (they have one in ludlow n all)....chances are they will stock something you could use or try olivers online.............I warn you now non of em are cheap.....
can
It is. the switch has a threaded part that comes through the front then theres a threaded lockring........
Looks like you would need to buy a 2gang dimmer switch and change the dimmers for toggle switches.
Where can I get a modern version of this?
Electrical Tools and Products
Tester Steve,
sparkydude,
