O
Octopus
Out of interest how to plan to get "past" the joists?
My question above was aimed at the OP - most DIYers haven't thought about how the lights get linked together!
We usually cut the bit of the joist out that is in the way. A quick nip tuck with the recip, job's a gooden!
Joists - DO NOT cut into them
Just thought I'd make very clear that my previous post was a JOKE! Of course we don't cut joists out lol, that would be madness!
It wouldn't have happened if you had known what you were doing, I hope you were adequately insured!Now you tell me!!! Was wondering why that kitchen ceiling fell down on me this morning ......
If the lights are in rows of 4 then measure the room and divide by 5, that will give you an idea of 4 equal spaces to look at, and 2 wide divide by 3 for the 2 rows. You can then mark the ceiling with a pencil where each divide is and stand and look at them to decide if the positions look right or not. You can then move them either way a few inches or so until it looks right. Then you have the problem with joists being in the way LOL, all part of the fun though.Im planning on removing two lighting points from my living room ceiling and replacing with 8 230v downlights (2rows of 4).
the room is 3.6m x 5.0m
In order to get the best use out of these would it be best to divide the ceiling into 8 imaginary sections an then use each centre as the new lighting point or divide the length by 5 and place at every metre and same for the width ( 3.6/3 so lights placed 1.2m apart?
ceiling/floor space is accessable from above and doesn't have any insulation inside
before anyone asks I have 2330 level 3 and 17th edition, I also have access to a metril mft that has a valid calibration certificate
I do that using a single core of 2.5mm! Great minds think alike, but I also make sure that no only is there the diameter available, but also the height!my method for ensuring i'm not too close to a joist ( assuming i can't locate them,) wire coat hanger angle with about 4" to go up the hole. then with the wire in , spin it round. if it goes full circle then there's no joist and then cut hole.
