I have a very old Wylex fuse board which is need to bring up to current standard Amendment 3.
I believe my property is supplied using a TN-S
I'm looking for a new consumer unit that is 11 or 12 way but not sure which brands are best as I plan on going for all rcbo.
So far I've seen Schneider, Hager and Wylex units
Schneider do one called Resi9 that's top of range but can't find any places that sell them, I can only see the Easy 9 for sale
Hager do one called Design 30
Wylex seem well stocked but I hear their rcbos are over sensitive and trip a lot, also they have had a recall in the past so I'm not sure on their quality in today's climate
I'm just wanting some advice on what you guys like to install, money isn't an object so I'm not after any budget stuff
Can anyone post pictures of their installs, be it cabinets or new metal consumer units
I know it's not in force at this very moment but it will be soon. I don't like the idea of a consumer unit that is capable of exploding and going up in flames be it installer error or bad quality, I would prefer a metal enclosure be it a metal CU or a cabinet.
Blooming heck, tell me you don't believe your plastic CU is going to explode or catch fire just because it's not metal?? Daz
I really think you need to look at the actual figures, but I respect that you want what you feel is the best.
The Hager Design 30 is a nice board. I have not had many issues with their RCBOs or MCBs. As for your installation, I would always used a trusted electrician and ask him what he uses or recommends.
Well I don't suspect mine is going to melt into a ball of flames but you have some manufacturers that cost cut these days and have poor quality control, I know because I work in producing gas meters. it's like most things in today's world, cheap **** from China ect, the number of fires that are happening at consumer units is a bit alarming though.
I'm not a huge fan of metal consumer units in case of them becoming energised either but I know it will be safer tham plastic should a fire occur
Maybe a plastic CU with a cabinet would be best
Thanks guys
How old is the board you have already, ever had any problems with it, etc, probably better made than most of today's garbage IMHO
Exactly my point Pete, I couldn't say for sure how old it is but I would guess it is as old as the house which was built in 1959, it's only a small 6 way board
But no I've not had any problems with it at all, It just doesn't have any protection should a fault occur which is another worry
I honestly think you're making a mountain out of a mole hill. If you are concerned then talk to your local trusted electrician for an opinion. Take a drive to the local wholesaler and look at the new boards compared to the previous designs.
We are all for safety, but I do feel the new changes have caused panic amongst some and that is a shame.
It's entirely up to you, if money is 'burning' a hole in your pocket then yes upgrade, you can't go far wrong with the schneider boards and the new Hager Design 30 looks very neat as well. Also as others have pointed out a fully trained experienced electrician is essential for this install who will provide you with a top class service and certificates to prove compliance. If you post your location one of the guys local to you can pm you and quote for the works.
Seeing as i need a new board away, not enough ways plus no rcd protection, it makes perfect sense to upgrade plus these new regs are coming in whether people agree with them or not.
So Hager 30 seems to be a favourite
Does the Schneider boards have a metal cover or plastic covers? the resi9 doesn't seem to be sold in many places online
No one mentioned Wylex, do people avoid these now ?
Oh i should mention that i will not be attempting to do this work myself in any case, a fully qualified electrician will be doing it, hopefully one who will provide a nice and neat install
nowt wrong with wylex. some time ago, there was a recall on electrium MCBs. these were use by other CU manufacturers as well as wylex. since the recall, there have been no issues.
At least you have thought it through. Sounds like a fair plan to me. Daz
To be honest he wants to replace the board because of not enough ways and no rcd. The metal enclosure is just to be on the safe side. Daz
Stockport
Which consumer units are best
messimagician,
rob28870,
