Currently reading:
Which consumer units are best
Discuss Which consumer units are best in the UK Electrical Forum area at ElectriciansForums.net
I have a very old Wylex fuse board which is need to bring up to current standard Amendment 3.
I believe my property is supplied using a TN-S
I'm looking for a new consumer unit that is 11 or 12 way but not sure which brands are best as I plan on going for all rcbo.
So far I've seen Schneider, Hager and Wylex units
Schneider do one called Resi9 that's top of range but can't find any places that sell them, I can only see the Easy 9 for sale
Hager do one called Design 30
Wylex seem well stocked but I hear their rcbos are over sensitive and trip a lot, also they have had a recall in the past so I'm not sure on their quality in today's climate
I'm just wanting some advice on what you guys like to install, money isn't an object so I'm not after any budget stuff
Can anyone post pictures of their installs, be it cabinets or new metal consumer units
I know it's not in force at this very moment but it will be soon. I don't like the idea of a consumer unit that is capable of exploding and going up in flames be it installer error or bad quality, I would prefer a metal enclosure be it a metal CU or a cabinet.
Blooming heck, tell me you don't believe your plastic CU is going to explode or catch fire just because it's not metal?? Daz
I really think you need to look at the actual figures, but I respect that you want what you feel is the best.
The Hager Design 30 is a nice board. I have not had many issues with their RCBOs or MCBs. As for your installation, I would always used a trusted electrician and ask him what he uses or recommends.
Well I don't suspect mine is going to melt into a ball of flames but you have some manufacturers that cost cut these days and have poor quality control, I know because I work in producing gas meters. it's like most things in today's world, cheap **** from China ect, the number of fires that are happening at consumer units is a bit alarming though.
I'm not a huge fan of metal consumer units in case of them becoming energised either but I know it will be safer tham plastic should a fire occur
Maybe a plastic CU with a cabinet would be best
Thanks guys
How old is the board you have already, ever had any problems with it, etc, probably better made than most of today's garbage IMHO
Exactly my point Pete, I couldn't say for sure how old it is but I would guess it is as old as the house which was built in 1959, it's only a small 6 way board
But no I've not had any problems with it at all, It just doesn't have any protection should a fault occur which is another worry
I honestly think you're making a mountain out of a mole hill. If you are concerned then talk to your local trusted electrician for an opinion. Take a drive to the local wholesaler and look at the new boards compared to the previous designs.
We are all for safety, but I do feel the new changes have caused panic amongst some and that is a shame.
It's entirely up to you, if money is 'burning' a hole in your pocket then yes upgrade, you can't go far wrong with the schneider boards and the new Hager Design 30 looks very neat as well. Also as others have pointed out a fully trained experienced electrician is essential for this install who will provide you with a top class service and certificates to prove compliance. If you post your location one of the guys local to you can pm you and quote for the works.
Seeing as i need a new board away, not enough ways plus no rcd protection, it makes perfect sense to upgrade plus these new regs are coming in whether people agree with them or not.
So Hager 30 seems to be a favourite
Does the Schneider boards have a metal cover or plastic covers? the resi9 doesn't seem to be sold in many places online
No one mentioned Wylex, do people avoid these now ?
Oh i should mention that i will not be attempting to do this work myself in any case, a fully qualified electrician will be doing it, hopefully one who will provide a nice and neat install
nowt wrong with wylex. some time ago, there was a recall on electrium MCBs. these were use by other CU manufacturers as well as wylex. since the recall, there have been no issues.
At least you have thought it through. Sounds like a fair plan to me. Daz
To be honest he wants to replace the board because of not enough ways and no rcd. The metal enclosure is just to be on the safe side. Daz
the acti9 ones will comply i recon with a metal door
the mc wylex boards look alright ive not fitted on yet though (10 way split load)
this is the first pic i found
Acti9? Why do these Schneider CU's have so many different names.
The only two I have seen advertised are the Easy9 and Resi9 although the Resi9 seems like gold dust
That Wylex one looks OK, which CU would you need for all rcbo's that can be mixed with mcb's? There are so many variations
acti 9 are the old merlin? i think
im quoting skeltons old post from a different thread
Easy9 is just rebranded Square D. Complete rubbish IMHO. Acti9 on the other hand, the rebranded Merlin isobar gear, absolutely lovely stuff!
Its not always about the hopeful benefits of a no seized up functioning RCD at the time of fault, but having old 3036 rewireable fuses is a pain in the bum for most people. So if anything I would want shot of them for MCB's, but thats me.
What I say to people is this who have old 3036 boards.
"What you have is on the old side, but I am not suggesting its dangerous. Just because its old doesn't mean its defunct and needs ripping out. Its like the wires running round your house, they may be old, but unless they show signs of deterioration why replace them. The only time I would advise you to perhaps look at rewiring part of a circuit or house is when you want to make more changes to the circuit which out weigh the time to just rewire the circuit.
The main difference between your old rewireable fuse box and a brand new latest specification Hager board, be it metal or plastic is that you have no RCD protection at the moment, which is going to help save your life in the event of a fault, and you have fuses that you have to rewire instead of just push a switch back up.
The new one also looks a lot nicer and will be properly labelled so you know which circuit is which.
If you would like to continue with your old fuse box, thats fine, but should you want to add any more circuits, you may need to then think about upgrading it as you have no space left in it, and the other issue is, should you want any electrical work carried out in your house such as new socket outlets and cables flush in the wall and so on, then unfortunately this work would need to be RCD protected, which then leads you back down the new consumer unit route.
Should you wish to upgrade, you have two options, you can either have a plastic consumer unit, or a metal consumer unit, both of which are excellent bits of kit, I only fit good quality products, the board I would fit would be made by a French company called Hager, they are very good, unfortunately some people charge the earth and fit cheap tat, Ill probably charge you less and will certainly fit a much better consumer unit.
The option of metal or plastic is basically to do with the latest Amd 3 of the regulations, although i don't have to fit a metal one at present, I do like to give people the choice. As of January next year, consumer units have to be made out of a non-combustible material, and the general concensus at present is that the only non combustible material is metal, but this is open to debate, but thats how it is at present. The reason that its going this way is because of fuse box fires where conductors have not been terminated properly, generally this is caused by inexperienced electricians over hardware failure. the point of it is, the fire would hopefully be contained within the consumer unit instead of it melt and spread.
If it was me I would upgrade the fuse box to the latest spec, I notice you have small children running around, and I would say that having RCD protection on your sockets is going to be better for them than not doing so should they poke something in a socket. Only last week (this is dead true by the way) my son had my keys and poked one in the earth terminal fully in at the top and switched it on, it would have only taken for him to poke another one in the live at the bottom and it could have been potentially fatal should there have been no RCD. An RCD is not there to be relied up on, but more of a "its better to have it than not" in the event of a fault.
Anyway, ill leave it with you, if you want that swapping out for a new one let me know."
Only last week (this is dead true by the way) my son had my keys and poked one in the earth terminal fully in at the top and switched it on, it would have only taken for him to poke another one in the live at the bottom and it could have been potentially fatal should there have been no RCD. An RCD is not there to be relied up on, but more of a "its better to have it than not" in the event of a fault."
If my Son done that I'd rather fit MK outlets rather than rely on an RCD, IMHO MK have the best child proof shutters.
Theres no guarantee that a child or anyone receiving a shock would trip an RCD, and I'd prefer not to put that to the test.
It was in a 4 way bar at my mother in laws house. How is an MK outlet going to make any difference? Surely if you poke something in the earth at the top its going to open the shutters? I have MK Logic DP throughout my house, changed them all the week I moved in.
Acti9 are their distribution boards
Easy9 are their consumer units
I would take a consumer unit to be a final board feeding circuits feeding current using equipment. I would take a distribution board as a main board feeding maybe several sub-boards or consumer units. Daz
a db is a consumer unit, just another name for them.
you get single and tpn 10 way+ consumer units under acti9
acti9 are merlin gerin
easy9 are square d
Or put another way, Acti9 is the series derived from the extremely popular and high quality Merlin Gerin Multi9 range, and Easy9 is some ---- derived from the old SquareD domae/qwikline garbage.
told ya dave
Reply to Which consumer units are best in the UK Electrical Forum area at ElectriciansForums.net
