One question= after 8 years here are you still a DIY enthusiast?Can anyone recommend a 7.5W LED GU10? I was using a Sylvania lamp but it's no longer produced. The 5W ones are not quite bright enough for my bathroom.
I'll second Megaman after recent advice from this forum.
They do a 6 and 7W LED, I got them online from Fastlec, really good service, ordered online got them 2 days later. You would be hard pressed to find them cheaper.
Megaman for me £5.50 + vat Wilts
ledhut sell dimmers on there site as well as the modules so you can use the same brand switch around the homeI've installed 60 lumilife GU10's from LED hut and the customer is well impressed. 5W and they're bright. First time I've used them. 13 of them are on dimmer switches which I have to replace to LED compatible dimmers. LED hut recommend varilight pro dimmers so will see how they fair. Anyone used them?
which dimmers are you using?So the dimmers work fine. Only problem is there is a slight hum from the lamps.
No I tried it on all the different settings and hums on each one. So there is 3 dimmers in the room. 5 leds on one 3 on the other and 2 on the other. All 5.7w
there are different modes on the varilight dimmers, have a look on there site there is a video guide that explains it i recon its probably in the wrong modeNormally a trailing edge dimmer should be silent you have not got it set to leading edge have you?
did you buy dimable led's? they sell both but the dimable are more expensiveI've installed 60 lumilife GU10's from LED hut and the customer is well impressed. 5W and they're bright. First time I've used them. 13 of them are on dimmer switches which I have to replace to LED compatible dimmers. LED hut recommend varilight pro dimmers so will see how they fair. Anyone used them?
