Discuss Which socket tester? in the Electrical Tools and Products area at ElectriciansForums.net
Trying to decide which socket tester to buy, I like the Socket and See 32 / 34 /36.
I already have a Megger 1553 which has RCD and Zs test.
The highest model seems to detect E/N incorrect polarity is this only if the installation has an RCD?
Assuming you're saying that the highest model can detect E/N swap then I don't see how that's possible from a simple plug in tester on it's own.
Most of them will do the job (assuming you just want a function test for the last part of your testing) I have a simple megger one Megger - MST210
i have the fluke SM300. it don't do N/E reverse, but it has 2 pretty touch buttons, 1 for RCD test and 1 for >50v touch voltage. obviously, these buttons are designed for kitchen fitters.
i payed 20 for a similar 1 ya see on ebay for 5 quid,, but thats when i leaned to hold a screwdriver..... it just tells you polarity and reverses of conductors... and you saying your's has buttons ,,aaaaa
Get one with a buzzer on it for plugging into sockets you cant see and checking which MCB switches that circuit. Until I got a buzzer one I was running up and down stairs all over the place.
(Need one without a buzzer as well cos they are annoying)
They are all much of a muchness really unless you want to do flashy things like testing the circuit!
I got a cheapy kewtech one, does the job, bout a tenner I think.
Cant see the point in all these test functions on a socket tester TBH, if you dont keep it in your toolbox for fear of damaging it because it cost you £50 and need to go to the van everytime you need it, you may aswell go for your MFT anyway.
All I use mine for is ID'ing circuits.
Reply to Which socket tester? in the Electrical Tools and Products area at ElectriciansForums.net
I’m trying to find an instruction manual/wiring diagram for an old Megger/Evershed Vignoles LT3 MK2 Earth Loop tester ….any info would be...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Recently changed a CU for a friend and today when visiting one of the RFC's RCBOs tripped. It was due attention anyway as open ring and no time to...
