Which Test Kit Do You Use???
  • Total voters
    120
I've had the robin Lego bricks, a fluke all in one, the megger 1553, some kewtech separates and am now currently using either the kewtech kt64 or megger.
The best tester will be the one which has test leads that don't knot up in-between tests. The amount of times I've run my fingers down to separate the bloody things... :mad:
Design a solution, and I will switch.
Can kewtech 64 carry out Ze tests, have been informed that fluke 1652 is unable to do so? would be grateful for advice....Ian
Fluke 1652B which I have will do voltage/frequency, continuity, IR, Loop, RCD trip and RCD ramp. Only thigs it cant do is method 1 earth spike and phase rotation, both of which I have little call for.....:D
I do have a Kewtech voltage tester that also works out phase rotation if I need to confirm, place the probes on the phase conductors and you act as a reference point..............
I've found metrel to be too inconsistent (witness testing can be very embarassing), and replacement leads and probes are pricey, I'm thinking of taking the plunge with a megger 1553 and the powersuite software but I don't know if it runs on windows 7, anyone know?
I bought my sanwa multi-tester when I visited Japan last year. I could say, the Japanese provides really good professional tools. Got it for a cheaper price too.
I have paws rather than hands so Megger - nice rubbery grippy cases, and quite robust when the inevitable impact strikes.
i have the mft1553 no trip loop takes so long, arms aching while holding the probes up to a light fitting, my old robin dlok was much much faster.
i have the metrel mi3101
Metrel MI3101 EuroTest AT Pro Kit Installation Tester Kit
easy to use and the software is straight forward to download straight to the pc. i like the pro kit for the ring main testing 6 croc clips and press the button does all the cross tests for you without having to connect in going outgoing etc
Totally agree! I was one of the first to spend £847 back in 2008. I am 100% happy with it although I haven’t had a chance to fully use the software perks.
i've never seen these sort of testers, looking at the features... i want one! why oh why did i not join the forum earlier!!!
I've got a Metrel Eurotest AT plus the Easi-Switch which makes testing ring circuits much easier and quicker!
The only negative comment is that the User Guides are poor, but this is compensated by excellent technical support guys when you ring them up
The Metrel UK MD did a presentation when I was on my course and he offered pricing direct for new trainees plus they do have ex demo stock to offer too!
I'm starting my 2391 insp testing course in jan 2011 & i am too in need of advice as to which mft to purchase.
Was originally looking at megger 1553 as thats only one i have some use of, all be it limited use.
Heard the fluke 1653b has more features & regarded by some as a better brand
BUT i have been looking at the features of the metrel at 3101 pro kit with the easy switch & it seems impressive.
I like he idea that you can complete the entire report on the machine, store it then print off directly to niceic certs.
Dont have an aversion to writing but having a totally complete record stored on my laptop seems like a good idea.
Also like the look of the easy switch.
Only cons i can see are 1. dont know much about the brand 2. price is quite high although it includes software. 3. may be complicated for a novice esp if instruction are not up to much as reported on here elsewhere.
Can anyone shed more light on this issue as i really want to have my own mft to practice with before starting the course?
also, is there a thread for best prices for these units?
