Two new 12V DC fans (100mm and 75mm inline/duct) are extremely noisy. Powered from household 240V mains with the usual DC transformer/ power supply - correctly rated for DC supply to these DC 12V fans). Why is this happening ?
Quiet fans cost more to make, as they need better bearings, better-balanced motors and impellers, more substantial housings etc. Small duct fans are in a very competitive market so they will not generally be as quiet as is technically possible.
The fan died on my NAS (Network Attached Storage) and as it's in the bedroom the replacement had to be very quiet. Took me ages to find a suiable fan and it cost a fortune. Would almost have been cheaper to by a new NAS unit and move my drives over.
or buy a set of headphones & put on a Pink Floyd album. no hear fan and good musik. 2 birds with 1 stone.
You didn't say if the fans are centrifugal or axial type and you didn't expand on what type of noise but here's a few pointers....
Before you pay a fortune for quieter fans just check the installation first. Make sure the fan and the ducts either side are properly supported, if the weight of the fan and ducting is hanging without supports it can distort the fan housing making it noisy.
Also check there's no ducting bends or harsh size transitions within a foot (350mm) of the fan, they run quieter if the airflow into and out of them is smooth and straight.
Check the static pressure isn't too high or too low, running a fan in a stall condition (too much restriction or long duct lengths) or in an almost 'free air' condition can increase the noise.
Finally check the power supply is up to the job, do a voltage test at the fan whilst it's running, if the voltage is low due to undersized transformer it can cause motor noise which is more like a rumbling sound.
HD2 2UB
United Kingdom
Why can 12V DC fans be so noisy ?
HOORRELL,
Marvo,
