Discuss Why is MCB tripping after replacing Honeywell controller with Tado receiver in the DIY Electrical Advice area at ElectriciansForums.net
sh0123
Tried replacing Honeywell controller (ST6400C) with Tado wireless v3+ receiver. After switching the power of on, the Tado controller lights up and connects to WiFi. However, when the hot water or heating is activated via Tado app, the fuse in the central heating circuit blows off and the MCB gets tripped. (It's a conventional boiler - Glowworm Micron with hot water cylinder)
Appreciate if some experts can advise on the potential issue. Attaching before and after wiring photos. Thanks in advance .
Difficult to see what you have done, looks like you have flex feeding the new unit and the normal fixed wiring on the old backplate so the proble is obviously wherever you have joined the two
Essentially behind the backplate are Spliceline connectors wherein the fixed wiring are connected to flex (L, N, HW NO and CH NO) respectively. Tomorrow I'll try taking few photos and upload here.
The reason to use flex was CH NO connection was a bit tight to work given shorter fix. If you think that fix to flex might be an issue causing the trip, then I'll try connecting fix wiring directly to Tado receiver. Would that connections be causing the issue here?
Fixing screws grazing cables and damaging insulation when being tightened are notorious for causing hidden faults in back boxes like you have everything is ok until the controller operates and you get problems
Reply to Why is MCB tripping after replacing Honeywell controller with Tado receiver in the DIY Electrical Advice area at ElectriciansForums.net
Hi there, We have recently replaced our central heating programmer with a Honeywell ST9400C. We now want to replace our old wireless room...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi hope someone can help me, it’s a bit of a long story so sorry in advance. Around 10 months ago we had a power cut and when the power was...
4K
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
