Right will try that thank you very much.Live in on 1 and live out to the pump from 3 there will be a slight differential on switching temperatures
If I put my tester on to show a complete circuit its the op way round on. Will turn the pump off when gets to temp and vice versa.Live in on 1 and live out to the pump from 3 there will be ai put my slight differential on switching temperatures
So swap the wire from terminal 3 to 2If I put my tester on to show a complete circuit its the op way round on. Will turn the pump off when gets to temp and vice versa.
Thanks Steve
Thank you so much for your help all working as it should.So swap the wire from terminal 3 to 2
