Discuss Wire up a temp controlled circulation pump. in the DIY Electrical Advice area at ElectriciansForums.net
Stella
Hi.
I'm wanting to connect a temp controlled unit that will turn on and off a hot water pump.
Can't weigh up how to do it as the wiring diagram doesn't make any sense to me.
Thank you.
Do you have anymore information is the hot water pump for a heating or cooling operation
It's for heating, I did forget to mention we are in Bulgaria.
Basically we have a log fire that is used to heat radiators, the pump is powered by plug in box. The idea of the thermo switch is so we can leave the box turned on all the time and when we light the fire the water start to get hot it will turn the pump on at a set temp and shut the pump off at that temp.
Live in on 1 and live out to the pump from 3 there will be a slight differential on switching temperatures
Live in on 1 and live out to the pump from 3 there will be ai put my slight differential on switching temperatures
If I put my tester on to show a complete circuit its the op way round on. Will turn the pump off when gets to temp and vice versa.
Thanks Steve
Thanks Steve
So swap the wire from terminal 3 to 2
Reply to Wire up a temp controlled circulation pump. in the DIY Electrical Advice area at ElectriciansForums.net
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
For the past few years, I have used a hydronic system (outdoor wood boiler) with both high and low temp working simultaneously. The low temp...
Our old three wire pump quit working. We wanted to replace it with a two wire. It was our understanding the pump would actually have three...
Hi all, I've noticed that my UFH pump is not always turning on as soon as the stat & valve calls for heat. This results in hot water passing...
Hi, I have a Beko DHR73431W heat pump tumble dryer that isn't heating. I'm thinking its beyond economic repair as I think the compressor has gone...
