Discuss wiring a modular contactor 2 pole n/o in the Electricians' Talk area at ElectriciansForums.net
Can anyone tell me how to wire a modular contactor.
I need to connect 1 - permanent live, 2 - Switched live and 3- the energising switch live.
I have the contactor with A1 , 1 AND 3 on top and A2 , 2 AND 4 on th bottom ??
A1 and A2 are coil connections (energising...either Live/neutral 230v or phase/phase 400v).....if you are just switching a single pole use either terminals 1 and 2...or 3 and 4.
sorry to gat crash your post side kick.
For a 230v coil
Just to clarify. For the coil connections for say lighting i would tap off 1(perm live) to a photocell and then sw back to A1. A2 loop off supply neutral. I could also run an overide in parallel to the photcell.
I assume if need be i could have a seperate supply for control of the coil?? to save looping of perm 1 and 2
connection.
Could you explain the 3 thrase coil set up please?
Reply to wiring a modular contactor 2 pole n/o in the Electricians' Talk area at ElectriciansForums.net
Hello all, I know this is very simple but I would like some advice please. I am installing a new circuit to feed 5 external floodlights. It is...
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
I want to check the insulation of the 3-phase 400VAC asynchronous squirrel cage motor. Motor's stator windings are connected in delta. I've read...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
Hello, I’m need some advice on how a contactor is wired please and where the neutral go. I’m told it is connected to eco 7 and controls 3 heaters...
