@spanner .... I'll re-iterate from my previous post in that their is alot more to simply connecting circuits up like install methods, fire safety, correct cable calcs... it honestly seems to me you have attempted this little project using a practical DIY book which give poor, dated and sometimes dangerous advice as has been discussed numerous times on here.
Your fault was a basic glaring mistake that should never have happened if cables were correctly identified and colour coded and with regards to the fault you are lucky this one operated a fuse/mcb or rcd as many other faults can exist that will put your family in danger and you may be unaware of both from a shock risk to fire risk.
Electrical reg's are just a starter you also have to comply with building regs and any ceiling you have fitted them into will still be required to maintain the existing fire protection i.e. Fire rated fitting or suitable hoods fitted.
Im just skimming the surface here but hope you start to appreciate the job you undertook 'may' fall far short of required and consider anon- related fire in the room with the new lighting can you assure us the ceiling will maintain protection from fire spread for approx 20mins if cut into plasterboard (as an example) .... IMHO i would sleep better knowing the fittings keep the fire at bay for 20mins to increase the chance of my family surviving and escaping.
Just something to ponder on when you consider those LV lamps and fitting without fire rating are one of the biggest fire risks in the house after the cooker.
