Discuss Wiring Bulk Head Lights in the UK Electrical Forum area at ElectriciansForums.net
what exactly does that mean Andy when you say slave - do they need a "master" of some type to work?
Yes, the master would be a 110V central battery system that Tel alluded to in post 6. Slave fitting seems to be the common description for these. This differentiates them from self contained emergency lights which have the battery built in to the light fitting.
If you know the manufacturer is Glamox, you could call them and ask them for more info. Are there any product or serial numbers ?
The number states GS/L3/SM/8/110/LSOH
8 will mean 8W tube, 110 will be the voltage, LSOH means low smoke zero halogen and will probably pertain to the plastic casing the bulkhead is made from.
If you ring Glamox with the code they will tell you exactly what it is, but it's probably as said.
You guys have been so much help, thank you it really is appreciated - what is a keen price from your experience to clear these - bear in mind we have 80 of the damned things
they're worth whatever someone is willing to pay. £14 sounds reasonable, but it's a limited market. suggest you find out the cost new, then base on that. say 50% of new price.
For those of you interested - this is about 2/3 of the stock we have
i bet your house will be the best xmas lit in your street this year. :eek:
Reply to Wiring Bulk Head Lights in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi all can a Maintained emergency exit bulk head light fed from non lighting circuit if it is correctly fused and test point provided if no...
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
Hi all, I'm wondering if someone can answer this question concerning a wiring scenario. I recently saw on a youtube video - a guy create a...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
