Search the forum,
Discuss Wiring For Electronic Thermostats For Wet Underfloor Heating in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
B
blokey
Hi Guys, could you please advise me as I have been getting differing answers whilst looking on the web. I am in the process of installing a new underfloor heating system. This will have 5 zones which will be isolated using 3 240V touchscreen programmable thermostats running into a Heatmiser UH3 wiring centre. I am about to purchase the cabling to run to the thermostats and I just want to confirm which cable I should use. As these are programmable thermostats I only need to have 3 cores (live/neutral/switched live) and an earth as each zone will be on it's own timer. I was thinking that 1.0mm 3core and earth would be suitable but this would be a minimum. Could you please confirm this before I start pulling up the floorboards etc. Thanks in advance.
Reply to Wiring For Electronic Thermostats For Wet Underfloor Heating in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi. I'm installing a wet underfloor heating system in my own house. What would you recommend as the best smart control system? I can hardwire...
m having a bit of an issue that is proving difficult to resolve. For 2 years I have been having no problems with my setup. I have a 3 zone house...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
