Discuss Wiring Spotlights For A Bathroom 12v? in the UK Electrical Forum area at ElectriciansForums.net
C
Connor Davis
I'm looking for someone to shed some light regarding domestic work and bathrooms,
I'm newly qualified spark but my apprenteship was completed on industrial sites so domestic is a new area for me, iv read up on the onsite guides and regs but would like some advice from people that work in domestic.
I brought these spotlights for my bathroom;
6 Pack of Halolite GZ10 / GU10 Aluminium IP44 Fixed Halogen Downlight - Polished Chrome:Amazon.co.uk:Lighting
It's stated these are for bathrooms and shower rooms and that they are IP44 rated, but there 230v, now in the onsite guide it says about 2 metre distance for 12v etc. Are these lights still okay to use in the bathroom or not?
Any advice would be greatly appreciated!
Lights, extract fans all need to be 12v. Look into bathroom zones for more info on moist and wet areas etc (zones)ip64 65 etc.
The onsite guide will tell you all you need, then you know you are right. A lot of people (not on here I,m certain) will miss guide you but you onsite guide won't.
IP44 rated downlights are suitable for both zone 1 and zone 2 in a bathroom. don't let anyone try and tell you that 230V is not allowed. have you ever seen a 12V shower?
botox.
Need to be 12v???? Are you sure?
What would be the point in having IP rated 230v equipment then, if you can only use 12v equipment in wet ares?
What a load of rubbish.......... this is not correct (stated for the benefit of anyone reading this later)
You being one of them ?
Reply to Wiring Spotlights For A Bathroom 12v? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I'd like to replace some MR16 halogen fittings on an exposed wooden beam to new GU10 fittings which I will be fitting led lamps into. The...
Hi everyone, I was wondering if I could get a little advice on a small project I plan to carry out over the next few weeks. I plan to install...
I
Hi Guys, New to the forum just looking for some advice on bathroom lighting issues. I searched and discovered i'm using this...
I recently moved house and the previous owner decided to replace the original 2 ceiling lights in the living room with single spots. These...
Hi everyone, My parents have some 240v GU10 down lights installed in the bathroom which all independently suffer from intermittent flickering...
12K
