Discuss Working out how many IR heaters in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
H
hightower
So when I get back to the school I plan to make my office a bit of an experiment room. Swapping the 1200x600s for 600x600 LED panels and the likes.
One of my ideas is to install IR heating panels. I've never actually encountered them, they are meant to be all the rave, and I think they would have a place in the school that could potentially save them money, or at the very least allow them granular control of heating (current archaic CH system doesn't allow for that). Has anyone used them and what do you think, but my main question is how to you work out how many IR heaters you need for each space? Is there a way to calculate it much like you can calculate lighting designs?
calculation would be complex. depending not only on room size and height of ceilings, but also on heat retention factors of the room/s ( insulation, draughts etc.). i'd be inclined to ask manufacturers for guidance here.
Have a look at Infrared Heating panels Calculator: How Many IR Panels Needed? - https://www.infralia.com/en/consumption/infrared-heating-calculation-requirements/
and
Calculate size of panels you need - https://www.warm4less.com/warm4less_calculate-size.html
When i had to have an op on my leg, i chose a private clinic as per the nhs choices thing. the clinic had these IR panels as heaters in the ceiling, they were really good and definitely are the way forward.
but did your leg get better quicker?
So how do they compare to a big old boiler that heats all the school (even when most rooms aren't calling for heat)? I'm guessing there's savings to be made.
What's the standard wiring procedure? Guessing they need wiring through some sort of controller, or is that typically built in to the unit?
You may want to look into this further, I have worked in hundreds of schools and only ever seen wet heating for the rads and fan heaters so there could be a reason for this.
Ha. Yeah sort of. They fixed one thing but the damn steroids afterwards masked and weakened something else...
The nurse said they use the ir heaters as they can direct the heat as they want it and its got therapeutic benefits.
I was aware they use it on horses but also in sports rehab too.
One of the links i put up earlier has somegood info on the site. The belgian company shows them as normal electric radiators and also ceiling variants. It appears they are wired as a normal one via a fcu? Might be wrong.
Itsgot me thinking though that given they use so much less electric. Compared to both gas central heating and other heaters they potentially can save a lot of £££s so i might look into this and see what the customer demand might be locally. I reckon you could do a whole house far cheaper than a new central heating system.
Only problem would be hot water.
Weird concept as you could be sitting there with a toasty body holding a thermometer that is reading zero.
Oh it won't be done on a whim, not a chance. Probably install one or two in my office first to see exactly how they work, and if they do the job we need I'll start doing a feasibility study
Strange , less clothes equals more heat , shouldn't bother the youth of today .
( I was the nerd wearing a duffle coat in sumer - Skinny and cold)
...Now defending from overhead IR/UV sources with my hat on !...
Reply to Working out how many IR heaters in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
In my line of work it's very rare that I ever have to change a DB. I'm largely in maintenance; occasionally have to add new circuits etc. so in...
Hi I’ve recently got my first home I’m not entirely sure when they were built I’m thinking possibly 60s or 70s? My problem is the storage heaters...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
