Discuss working out volt drop in the Electricians' Talk area at ElectriciansForums.net
Reg 1: Use Common sense.
or it'll be something out of Chapter 3 about discrimination.
yes. i know, but was seeking a specific reg.
531.2.9 only asks for discrimination between RCDs when it is necessary to prevent danger.
I was always taught that the test button mechanically tests the device. I'm not sure about RCBO's.
well yes to an extent, it checks the electro-mechanical aspects out, the test button usually switches a resistor from the incoming L terminal to the outgoing N terminal so it checks the trip coil operation too.
he is a trainee, i wouldnt be suprised if he is a first year
it sounds like a homework question, if it is its in the wrong section
he mentions mv/a/m on basic domestic circuits so its homework, why would you need to work this out when it gives you all that info in bs7671 and onsite guide if we wanted it
Sounds like he wants to do the job because he's applying for elesca registration in another thread he started.
That makes sense, but wouldn't cause an upstream device to operate as it only diverts current to neutral so no imbalance would be detected on the other device.
Hence my earlier reply to Lucien ;) , I am not sure why the RCBO tripped out the upstream one that I did at work though, but it did.
I might tomorrow fit my spare RCD that I keep, to a plug and lead , and see if it trips out the house RCD lol :)
My downstairs sockets at home are fed from a rcbo and I spurred a outside rcd socket off this circuit, now every time I use the outside socket I always push the test button and it has never tripped the upstream rcbo.
I wonder if it only happens with an RCBO downstream ?, as I said maybe it was due to only certain types or possibly with the functional Earth when this is present.
I originally opened my mouth based on my earlier experience without thinking , then I thought about it and came around to Luciens way of thinking. :)
Reply to working out volt drop in the Electricians' Talk area at ElectriciansForums.net
Why is this still a thing, just done a quick calculation with the TLC volt drop calculator and if its a non lighting circuit the recommended size...
I am trying to understand 3 phase volt drop. I understand single phase VD. Lets say we have a 70 meter run of 35mm, 5 core cable from the supply...
Hello, New trainee electrician so sorry if this is a dumb question I feel confident with calculating the volt drop for a ring and radial circuit...
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
I'm getting a little confused about volt drop and 24v. I want to fit an LED strip light. 8m of lights 7w/m. It would be easier to have the 24v...
5K
