Discuss Xpelair XIM X 100 inline extractor fan in the UK Electrical Forum area at ElectriciansForums.net
carole
hi, I'm in need of a little help, I have bought an inline extractor fan, the booklet shows I can fit a 3 pin plug to it or hard wire with a switch, I want to use a plug but I am not sure if I have wired it on correct as it has no power, I was wondering if anyone could advise, the diagram shows
L1 Brown, L2 Black, N White and my plug of course is brown, blue and earth, I have tried the live in L1 and L2 and get no power
thanks in advance
Seems as if you have a timer version, which as far as I know will not be suitable for a plug top connection. Are you sure about the model no. above?
Hm
The diagram I have shows this
Which looks easy peasy
I've shown you mine, can you show me yours?
(diagram I mean)
Have you connected the blue to the N (neutral) terminal. Can you post a pic of the actual fan terminals.
You need to put the blue on N
and the brown on L1 or L2 depending on if you want high or low speed.
In the drawing they have shown a separate switch, so you can select the speed from the switch.
Reply to Xpelair XIM X 100 inline extractor fan in the UK Electrical Forum area at ElectriciansForums.net
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
