Discuss You to can be an Electrician in the UK Electrical Forum area at ElectriciansForums.net
Glad he said what the pencil and tools were cos initially I was lost. Could have used boxes with earth terminals, I don't know.
This thread actually reminds me of a little tip I was given many moons and lengths of pvc conduit ago, and I would like to pass it on to those who don't know it.
Instead of tying a piece of cable onto the top the spring, first thread the cable down the inside of the spring and then knot it at the bottom of the spring. This method saves stretching the spring when you pull it out if it is tight and also stops it smacking you in the face at the same time.
Don't understand the bend at all he could have come up front the left side switch, mind you I am still trying to remember the name of all those tools.
Reply to You to can be an Electrician in the UK Electrical Forum area at ElectriciansForums.net
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
Good morning. Quick question, We hired a registered electrician to carry out an EICR, but after some searching it appears he subcontracted it...
Has anyone got experience terminating steel conduit from 1935 (so likely imperial measurements) into a new metal enclosure? This was the work of...
Doing some work in a commercial restaurant/kitchen the builders had already boarded and plastered the walls meaning my only viable route is to use...
The electrician that installed my cooker circuit put in 10mm cable with a 32a fuse, a 45a cooker switch and 10mm cable to the backplate for behind...
