- Reaction score
- 17,112
I've broken my blowlamp, will the gas axe be ok instead?
Discuss Your thoughts on bonding this gas pipe in the UK Electrical Forum area at ElectriciansForums.net
Blowlamp, burn the paint off.
Before you startshouting, think about it.
pis on the paint...
come back in a week
if your anything like the corrosive bastid that i am then it should work a treat...
Thought about it. Blow lamp on a live gas pipe. Not the smartest of moves.
Probably nothing. However he is not gas safe or is qualified to work near gas. A gas distribution company would throw the book at him.Well what exactly will happen if you do apply a blowlamp to a live iron gas pipe?
no oxygen in the gas pipe for the gas to burn...Thought about it. Blow lamp on a live gas pipe. Not the smartest of moves.
escaping gas under pressure will just burn/flare..Once upon a time plumbers would locate small leaks in gas pipes by holding a match near the joints, the leaking gas would ignite and you'd get a little flame at the bad joint.
But then I wouldn't put anything past a determined plumber!
its like a lingerin fart innit....Remind me why something inert is dangerous
well...if the inert gas is pre-mixed with oxygen....then its much more dangerous than just inert gas on its own....Depends which definition of inert you use.
Inert - not moving or inert - chemically inactive
Reply to Your thoughts on bonding this gas pipe in the UK Electrical Forum area at ElectriciansForums.net
