Gents.
I did some earth loop tests on Rolec power pedestals (2x 16 amp outlets) that are harbour side, looped in and out from one another.
Three months ago I got Zs readings from about 1.2 ohms to 0.50 ohms. This time round the readings are all less than 0.01 ohm.
Megger MFT meter.
The RCD in each meter trips off just fine.
I am using a LO 3 wire test as I am plugging into the sockets (as usual) cannot take readings directly from terminals as there are over 300 to do.
What would cause such a drop in values, we are nowhere near a substation etc, anyway I would have seen low readings before if this was the case.
Any ideas ?
Many thanks.
Megger MFT meter.
Any ideas ?
Many thanks.
