Discuss Invoicing in the Business Related area at ElectriciansForums.net
Yep im using it, have been for the past 2 years
Anyone here used or using SliQ invoicing software?
What are you using currently?
A combination of excel and word. Just after something a bit more streamlined, vat breakdown, discount, automatic sequential numbering etc... and also something that saves as pdf without having to convert.
Not the main point, but Word and Excel will both save straight to pdf (I'm using 2007).
Openoffice can save to pdf too, there should be a option for it (export directly as pdf). Also any program that you can print from can save as a pdf you just need to install a pdf printer such as cutePDF writer. once installed when you want a pdf you go to print then in printer selection you choose cutePDF and then print it will then save it as a pdf
I was about to say get someone to automate the processes that you carry out. Someone who is capable of writing software using Visual Basic will be quite capable of tailoring MS Office to meet your needs. That said, having read further into the thread and discovered that you use Open Office, I am not familiar with the options available to you to tailor its functionality.
I'm sure that service would cost a lot more than the £50 that SliQ are asking for even if it could be done with OO. I'm pretty certain I'll be using software, I only ask about SliQ because that was the one which was recommended to me.
So you are going to make a really important business decision because of £50.
Madness
What do you mean?
if you can buy software for 50 quid that does everything you want, why would you want to pay someone £100s to design something probably not as good with no updates or support.So you are going to make a really important business decision because of £50.
Madness
Because a custom piece of software will do exactly what you want and will not need updating.
Reply to Invoicing in the Business Related area at ElectriciansForums.net
